Group: DynoMotion Message: 12805 From: daveymahomh600e Date: 2/20/2016
Subject: Recording Commanded vs Actual position while Running Gcode
Is there a way to record for analysis the commanded vs actual position of an axis while it is running a gcode program? A data point of each once every second or so would be plenty accurate enough. I am running some high-load programs and I fear there may be following issues.
Any suggestions for generating this type of data would be much appreciated.
Thank you in advance,
David.
Group: DynoMotion Message: 12807 From: TKSOFT Date: 2/20/2016
Subject: Re: Recording Commanded vs Actual position while Running Gcode
Hi David,
Do you have encoders on the axes of interest?
See the \C Programs\CaptureXYMotionPosDest.c example.
Change the for k loop to skip the number of 180us time slices between samples.
On 2016-02-20 12:50, david.m.stevenson@... [DynoMotion] wrote:
> Hi Tom, > > Is there a way to record for analysis the commanded vs actual position > of an axis while it is running a gcode program? A data point of each > once every second or so would be plenty accurate enough. I am running > some high-load programs and I fear there may be following issues. > > Any suggestions for generating this type of data would be much > appreciated. > > Thank you in advance, > David. >
Group: DynoMotion Message: 12809 From: David Stevenson Date: 2/20/2016
Yes there are encoders. Thanks for the file info.
David.
On 2/20/2016 1:11 PM, tk@... [DynoMotion] wrote:
Hi David,
> Hi Tom,
> appreciated.
> David.
This email has been sent from a virus-free computer protected by Avast.
www.avast.com
